GTM Presistence Records
Can you let in the following command is correct to view the persistence records on a GTM
tmsh delete ltm persistence persist-records
regards
Andy
so you have two things wrong - you want to use
tmsh show
and you want to reference the gtm module.
So the command would be something like
tmsh show gtm persistence persist-records
. I haven’t tested this on GTM so you should confirm that.
