GTM Packet Capture command
Hi All,
I have started working on F5 GTM recently and stuck with the tcpdump commands for it.
Need help on tcpdump commands for wideip to check if the wideip is working correctly.
Also are there any step by step guide to check and troubleshoot wideip application issue.
Hi Aditya,
You can try using the following formats by changing the host IP as per your configuration.
tcpdump -vvv -s0  -nni 0.0:nnnp udp port 53 and host 1.2.3.4 -w /var/tmp/$(/bin/hostname)_$(date +%Y-%m-%d)_$(date +%H:%M).pcap
First, find out which interface you want to sniff with the “ifconfig” command. If the destination server is located on an interface called “vlan1275” you can dump all DNS traffic to a specific IP address thus
tcpdump -i vlan1275 udp port 53 and host 1.2.3.4 -w /var/tmp/$(/bin/hostname)_$(date +%Y-%m-%d)_$(date +%H:%M).pcap
You can refer following articles
K411: Overview of packet tracing with the tcpdump utility
K00463541: A breakdown of the tcpdump utility, recommended actions, and information to help you use and apply it to the BIG-IP.
HTH
:folded_hands:
You can have a look this link, https://clouddocs.f5.com/training/community/dns/html/class4/module1/lab4.html.
I hope would be helpful.
