Last months working on a GTM implementation and everything is working fine except the GTM is not responding with all NS records. GTM is configured in HA using two F5 4000 Big IPs.
GTM is currently configured in the zone gtm.cavali.com.pe and this zone is being delegated at the server provider in their public DNS in domain cavali.com.pe. The delegated nameserver configuration is pointing to primary nameserver cvlbal01.cavali.com.pe and secondary namserver cvlbal02.cavali.com.pe each having public IP´s that exist on the GTM as the listeners. We use CNAME to direct the DNS request to the GTM like for example. www.cavali.com.pe has a CNAME pointing to www.gtm.cavali.com.pe.
If I try to retrieve the NS records connecting directly the the nameserver on the GTM using nslookup it only shows me the SOA record and the primary NS server.
The nameserver configuration is as follows
If I look at the traffic coming in to the GTM I do see a NS query and a response with cvlbal01.cavali.com.pe as the nameserver. So why the secondary NS record is not being served as well?
I should reveive something similar like the following example when querying for the nameservers of Google.
When I do the zonecheck using https://zonemaster.net it also responds with the following
Does anyone has an idea why only one Nameserver record is being returned and why te zonemaster check is failing?
