The GTM HA pair’s have a self ip each, and a floating ip. I have the listener set to the floating ip.
The virtual servers in the GTM are showing some as down, even though the LTM says they are up. I get the error Monitor bigip from gtmd: no reply from big3d.
Do I have my listener setup correctly? Should it be the floating ip in the pair? Its set to UDP also, on all vlan’s.
