Hi Folks,
Recently I have faced a challenge that the F5 box has GTM, LTM & ASM on the same box and I need to do the inbound and outbound load balancing. I am unable to figure out as to how the Load balancing will be done through the box which is sitting out side the firewall for inner servers and how the internal users will be served Do i have to create separate Virtual servers set one set on the Public IP addresses and another on Private… really need some guidance or recommendation…
Regards,
