Guys, I want to configure the GTM in a way where it chooses VS based in least connections but once this is done I want it to stick the LDNS to the same VS based on a /24 CIDR.
I see that there is a persist option under the wideip config, however enabling this only works for /32’s.
The only place I see that you can change the sticky mask is when using static persist load balancing method. However when I use static persist I no longer can use the least connection method.
Does anyone know how I can balance based on least connections and also persist on a /24 level? Thanks.
