GTM Load Balancing between VS and CNAME
We are currently using Global Availability to LB between to Virtual Servers.
I need to add a CNAME to a CDN into the mix. Seems this is pretty doable through an iRule.
The problem with this is that we only use the CDN during peak hours so I need to be able to manually switch between the CNAME and the Virtual Servers. I guess this could be accomplished by adding and removing an iRule that references the CNAME as needed, but I am hoping there is an “easier” way similar to the way the Global Availability algorithm works with Virtual Servers.
Any suggestions would be appreciated, thanks.
You could do this in an iRule, just set your peak start/end times, then if { peak times } cname … else { pool VirtServers }
Jason, thanks for the suggestion. Unfortunately, the powers that be have forced me to leave it as a manual step.
I’ve implemented what seems to be the simplest solution by creating a CNAME pool along with the VS pool and, using Global Availability, ordering the pools accordingly.
Originally I just created a simple iRule that I could add and remove,
when DNS_REQUEST {
cname “url.example.net”
ttl 300
but it was just an extra thing to confuse the “operators” doing day to day DNS management.
