GTM: https monitor
Hi, I’ve configured an https control on a BIGIP1600 GTM pool member for a service configured on BIGIP3600 LTM, it fails with the following error:
Jun 11 14:59:05 gtm2 gtmd[1894]: 011ae0f2:1: Monitor instance yyy.yyy.yyy.102:443 UNKNOWN_MONITOR_STATE --> DOWN from yyy.yyy.yyy.161 (state: protocol mismatch)
If I launch “telnet yyy.yyy.yyy.102 443” from the GTM the connection goes up.
Should I change cypher list on the GTM?
Thank you for your attention
The LTM should be added under Global Traffic → Servers as a BIG-IP System. Then under the LTM server object itself, you add a virtual server for your yyy.yyy.yyy.102 service on port 443.
GTM will run iQuery with the LTM to determine the health of its virtual servers.
I’ve made a capture on the LTM to catch the GTM monitor traffic:
tcpdump -i any host yyy.yyy.yyy.161 and port 443 tcpdump: listening on any 15:58:49.443234 802.1Q vlan4093 P0 yyy.yyy.yyy.161.34108 > yyy.yyy.yyy.102.https: S 449817390:449817390(0) win 5840 (DF) 15:58:49.443978 802.1Q vlan4093 P0 yyy.yyy.yyy.102.https > yyy.yyy.yyy.161.34108: S 3570641870:3570641870(0) ack 449817391 win 4380 (DF) 15:58:49.444944 802.1Q vlan4093 P0 yyy.yyy.yyy.161.34108 > yyy.yyy.yyy.102.https: . ack 1 win 5840 (DF) 15:58:49.444950 802.1Q vlan4093 P0 yyy.yyy.yyy.161.34108 > yyy.yyy.yyy.102.https: P 1:119(118) ack 1 win 5840 (DF) 15:58:49.445507 802.1Q vlan4093 P0 yyy.yyy.yyy.102.https > yyy.yyy.yyy.161.34108: P 1:123(122) ack 119 win 4498 (DF) 15:58:49.446407 802.1Q vlan4093 P0 yyy.yyy.yyy.161.34108 > yyy.yyy.yyy.102.https: . ack 123 win 5840 (DF) 15:58:49.446411 802.1Q vlan4093 P0 yyy.yyy.yyy.161.34108 > yyy.yyy.yyy.102.https: P 119:162(43) ack 123 win 5840 (DF) 15:58:49.446903 802.1Q vlan4093 P0 yyy.yyy.yyy.102.https > yyy.yyy.yyy.161.34108: . ack 162 win 4498 (DF) 15:58:49.447872 802.1Q vlan4093 P0 yyy.yyy.yyy.161.34108 > yyy.yyy.yyy.102.https: P 162:190(28) ack 123 win 5840 (DF) 15:58:49.448158 802.1Q vlan4093 P0 yyy.yyy.yyy.102.https > yyy.yyy.yyy.161.34108: R 123:123(0) ack 190 win 4569 (DF)
It seems that the LTM sends a reset
Luigi, the proper setup is to configure iQuery between the GTM and LTM, and LTM will report the health of the virtual server to GTM through the iQuery connection. You would build your GTM pool to include the virtual server configured under the LTM server.
Check out section “Defining BIG-IP LTM systems” in this document:
Hi Cory, of course I’ve already made all the necessary operations to configure the LTM and GTM appliances like explained in the link you’ve posted.
Then you will not need to apply a monitor to the GTM pool, as the GTM is inheriting the health status from LTM.
Ok, I’ve taken off the monitor from pool, but I’ve the same result. Anyway on the LTM the status is OK.
Should I remove the monitor from the pool member too?
Only remove the monitor from the GTM pool.
So is the pool member not being reported as up after removing the GTM pool monitor?
Yes, just the pool member, because the ather one in the same pool is up
So your pool contains two members. One is a virtual server on the LTM, and what is the other one?
Could you post your GTM pool configuration?
Yes, the otherone is a virtual server on a remote LTM, the GTM contact it by routing. The same monitor on this last member (the virtual server on the remote LTM) works great.
Would it be possible to not have a monitor applied to your GTM pool, and just apply a monitor to the virtual server on the remote LTM? Doing this should enable both members to be marked up without any pool level monitoring.
Here you are the config:
(gtm2.domain.external.it yyy.yyy.yyy.161) dumped 06/11/2014 17:52:47 CEST - GTM Version 9.4.8
globals { probe_protocol { icmp } }
// *** Data Center Definitions (2) ***
datacenter { // 2 server(s) name “NY” location “NY” server “LTM_NY” server “GTM_NY” }
datacenter { // 2 server(s) name “W” location “W” server “LTM_W” server “GTM_W” link “firewall_internet” }
// *** Monitor Definitions (10) ***
monitor “testA” { defaults from “https” interval 30 timeout 120 probe_interval 0 probe_timeout 5 probe_num_probes 1 probe_num_successes 1 dest www.www.www.127:443 // https cert “” send “GET /” username “” recv “” compatibility “enabled” password “” key “” cipherlist “DEFAULT:+SHA:+3DES:+kEDH” partition “Common” }
monitor “bigip_GTM_W” { defaults from “bigip” interval 30 timeout 90 probe_interval 0 probe_timeout 1 probe_num_probes 1 probe_num_successes 1 dest yyy.yyy.yyx.161:4353 // 4353 partition “Common” }
monitor “https_B” { defaults from “https” interval 30 timeout 120 probe_interval 0 probe_timeout 5 probe_num_probes 1 probe_num_successes 1 dest www.www.www.144:443 // https compatibility “enabled” recv “” cipherlist “DEFAULT:+SHA:+3DES:+kEDH” cert “” username “” key “” send “GET /” password “” partition “Common” }
monitor “testgtm_NY” { defaults from “http” interval 30 timeout 120 probe_interval 0 probe_timeout 5 probe_num_probes 1 probe_num_successes 1 dest yyy.yyy.yyy.199:80 // http username “” password “” recv “” send “GET /” partition “Common” }
monitor “B” { defaults from “https” interval 30 timeout 120 probe_interval 0 probe_timeout 5 probe_num_probes 1 probe_num_successes 1 dest www.www.www.144:443 // https send “GET /” cert “” compatibility “enabled” username “” key “” recv “” password “” cipherlist “DEFAULT:+SHA:+3DES:+kEDH” partition “Common” }
monitor “B_NY” { defaults from “https” interval 30 timeout 120 probe_interval 0 probe_timeout 5 probe_num_probes 1 probe_num_successes 1 dest yyy.yyy.yyy.102:443 // https cert “” username “” recv “” key “” send “GET /” cipherlist “DEFAULT:+SHA:+3DES:+kEDH” password “” compatibility “disabled” partition “Common” }
monitor “testgtm” { defaults from “http” interval 30 timeout 120 probe_interval 0 probe_timeout 5 probe_num_probes 1 probe_num_successes 1 dest yyy.yyy.yyx.128:80 // http username “” password “” recv “” send “GET /” partition “Common” }
monitor “https_testA” { defaults from “https” interval 30 timeout 120 probe_interval 0 probe_timeout 5 probe_num_probes 1 probe_num_successes 1 dest www.www.www.127:443 // https key “” recv “” cert “” cipherlist “DEFAULT:+SHA:+3DES:+kEDH” send “GET /” password “” compatibility “enabled” username “” partition “Common” }
monitor “B_NY_http” { defaults from “http” interval 30 timeout 120 probe_interval 0 probe_timeout 5 probe_num_probes 1 probe_num_successes 1 dest yyy.yyy.yyy.102:80 // http username “” password “” send “GET /” recv “” partition “Common” }
monitor “C_NY” { defaults from “https” interval 30 timeout 120 probe_interval 0 probe_timeout 5 probe_num_probes 1 probe_num_successes 1 dest yyy.yyy.yyy.212:443 // https username “” compatibility “enabled” password “” send “GET /” cipherlist “DEFAULT:+SHA:+3DES:+kEDH” cert “” recv “” key “” partition “Common” }
// *** Link Definitions (1) ***
link { // datacenter=W name “firewall_internet” address yyy.yyy.yyx.2 monitor “gateway_icmp” }
// *** Server Definitions (4) ***
server { // datacenter=W, VS=3 name “LTM_W” type bigip box { address yyy.yyy.yyx.52 unit_id 1 } box { address yyy.yyy.yyx.53 unit_id 2 } monitor “bigip” vs { name “B” address zzz.zzz.zzz.102:443 // https monitor “B” translates to www.www.www.144:443 } vs { name “testA” address zzz.zzz.zzz.151:443 // https monitor “testA” translates to www.www.www.127:443 } vs { name “testgtm” address zzz.zzz.zzz.199:80 // http monitor “testgtm” translates to yyy.yyy.yyx.128:80 } }
server { // datacenter=W, VS=0 name “GTM_W” type bigip box { // gtm address yyy.yyy.yyx.161 unit_id 1 } monitor “bigip” }
server { // datacenter=NY, VS=2 name “LTM_NY” type bigip box { address yyy.yyy.yyy.148 unit_id 1 } box { address yyy.yyy.yyy.149 unit_id 2 } monitor “bigip” vs { name “B_NY” address zzz.zzz.zzx.102:443 // https monitor “gateway_icmp” translates to yyy.yyy.yyy.102:443 } vs { name “testgtm_NY” address zzz.zzz.zzx.199:80 // http monitor “testgtm_NY” translates to yyy.yyy.yyy.199:80 } }
server { // datacenter=NY, VS=0 name “GTM_NY” type bigip box { // gtm address yyy.yyy.yyy.161 unit_id 1 } monitor “bigip” }
// *** Pool Definitions (3) ***
pool { name “B” ttl 30 preferred ga alternate null fallback drop_packet partition “Common”
member { address zzz.zzz.zzz.102:443 monitor “B” partition “Common” } member { address zzz.zzz.zzx.102:443 monitor “B_NY” disabled partition “Common” } }
pool { name “testgtm” ttl 30 monitor all min 1 of “testgtm_NY” “testgtm” preferred ga alternate null fallback null partition “Common”
member { address zzz.zzz.zzz.199:80 monitor “testgtm” partition “Common” } member { address zzz.zzz.zzx.199:80 monitor “testgtm_NY” partition “Common” } }
pool { name “testA” ttl 30 preferred rr partition “Common”
member zzz.zzz.zzz.151:443 }
// *** Wide IP Definitions (3) ***
wideip { name “B.external.it” pool_lbmode rr partition “Common” pool “B” }
wideip { name “testgtm.domain.external.it” pool_lbmode ga partition “Common” pool “testgtm” }
wideip { name “testA.external.it” pool_lbmode rr partition “Common” pool “testA” }
// *** Application Definitions (1) ***
application { name “testB.external.it” partition “Common” }
So the pool member that won’t show as up is your B_NY virtual server on your LTM_NY GTM server object?
Yes. Why in the case of the B_NY the GTM makes a check by probing the virtual server on 443 port (like showed in the traffic capture), while for the remote one (B) it doesn’t? I’ve noticed it doing a capture on LTM_W (the LTM where B is defined), in fact I had no traffic coming from the GTM on the 443 port, only traffic for the big3d process. Despite that the healtmonitor for B is ok.
I think in the event that you configure a health monitor on a GTM pool member that’s actually a virtual server on an LTM, the GTM doesn’t use it as one may think.
It looks like you have your GTM configured correctly with both LTM_NY and LTM_W as servers, and the target LTM virtual servers as your GTM pool members, such that no health monitoring at all should be necessary at the GTM level.
Can you pull all monitoring configured at the GTM level whether it’s on the pool or on the member/virtual server?
“Can you pull all monitoring configured at the GTM level whether it’s on the pool or on the member/virtual server?” I can’t understand, could you explain it better again? Thank you
Hi, I’ve solved making ridiculous operations:
  • delete vs from the pool
  • delete vs from the relative server
  • recreate from zero all without monitors
What a weird behaviour!
It works only if I leave all the monitors field empty and “inherit from pool” in the vs
Thank you
Good to hear you got it resolved.
