GTM health monitor fails on pool, but not on member.
I am running GTM 11.4.1 HF1.
If I assign the default HTTP health monitor to a GTM pool, the pool goes red. If I remove the pool health check and add the HTTP health monitor to the member that’s in the pool, the pool goes green.
The GTM has no problem making a telnet connection on port 80 to the member. It can ping and tracert to the member without problem.
This behavior happens for any pool and member combination. Is this expected behavior? Why can I not set a pool health check and have it work correctly? I spend most of my time in LTM and am accustomed to LTM behavior.
thanks!
Does the server respond as expected if you issue the curl command?
From bash shell:
curl http://serveripaddress
Yes. From the GTM, when I open the member server’s IP address with curl, I get expected HTML from the default document.
The results should be the same between the two. Have you tried capturing the network-behavior with tcpdump, and is this GTM part of a network of iquery-connected GTMs/LTMs?
1) I have not make any packet captures yet, as this hasn’t been a critical issue.
2) This GTM does communicate with LTMs using iquery, however the GTM does not use that data. All server/member/node objects in the GTM are added manually.
I suppose it’s good to know that this behavior is not expected. This might motivate me to open a case with F5 support to inquire about the issue. At least I know it’s not working how it is supposed to. Much of the config in the GTM is not intuitive to me, so sometimes I’m never really sure how things are supposed to work.
Short answer is no, this is not expected behavior. A support case is your best bet.
I’m experienced the same problem. Did you solve this?
GTM marks down the Pool because the member (VIP) seems to be down, but the VIP in the menu: GSLB → Servers → “PoolServer1” → Virtual Servers .. is still up. Seems to be a problem with the “http”-health-check???
I have not resolved this. I have not opened a support case yet. I have seen one other GTM problem with a health check not working correctly for a pool, however I think it might be resolved by HF5 for 11.4.1. So I am planning to install that as soon as management approves it. I need this patch for other bug fixes as well.
If HF5 does not resolve the issue, then I will pursue it with F5 support.
@ken b and @matthiasritter - i doubt this solves the pool-level monitor vs. pool-member-level monitor discrepancy, but it’s worth examining when troubleshooting GTM monitors
  1. do you have multiple GTM data center objects configured?
  2. in your GTM/LTM iquery mesh, regardless of having the correct rules allowing iquery communication, do you have firewalls/ACLs separating GTM/LTM devices that are in the same data center?
  3. what does /var/log/gtm say about the pool-level and member-level monitors when they fail/pass?
  1. Yes, we have 2 data center objects.
  2. Yes.
  3. Unfortunately I have not been able to reproduce the problem with the non-production objects I have to work with.
my apologies if the following is overkill - just want to lay out some iquery functionality that is often vague in documentation and misunderstood until you have to dig in:
regarding the earlier comment “This GTM does communicate with LTMs using iquery, however the GTM does not use that data. All server/member/node objects in the GTM are added manually.”
iquery is used between GTM/LTM not only to autodiscover LTM virtual servers and monitor health of the F5 devices, but also to pass on health status of virtual servers from the LTM on which a vs is configured to a GTM that is configured with that vs as a GTM vs object, regardless of whether the server object was manually added or autodiscovered - if a GTM vs was manually added to the LTM server object and a bigip monitor is assigned to that server object, the GTM will ascertain the vs status via its iquery connection from that LTM.
when a specific non-bigip monitor is assigned to a GTM pool/member/server, the GTM may delegate that monitoring activity to a different iquery-connected F5-device. it doesn’t necessarily handle the monitoring itself. from my experience, it will choose a live F5 device (GTM or LTM) in the same GTM data center as the monitored virtual-server object. for example, if an http monitor is assigned to a GTM pool/member in DC1, the GTM may tell another LTM in DC1 to monitor that object and relay the status back via iquery. this can cause issues if there’s a firewall that prevents the selected F5 device from hitting that server object via port 80, 443, etc. required by the non-bigip monitor
I experienced similar issue of GTM pools being marked down when upgrading from 10.2.4 to 11.4.1 HF4 (HF5 was not out). I punted to previous version to investigate. All server/member/node objects in the GTM were added manually. I suspected something changed with the custom health monitors, but it looks like you had the same problem with default monitors. I do not currently have a GTM/LTM iquery mesh. I plan to configure iquery with our LTMs when I get the GTMs up to 11.x. All pools are green in 10.2.4, so firewall rules should be in place.
Hi Shaggy , I do have question regarding GTM monitoring the LTM vs using iquery On GTM I have Virtual Server ABC_VIP_http ,Called in Pool ABC_Pool,WIP= abc.com GTM will give Virtual Server IP=1.1.1.1 in resolution to abc.com Virtual Server name=ABC_VIP_http Virtual Server IP = 1.1.1.1 Virtual Server Port=80 On LTM Virtual Server name=ABC_VIP Virtual Server IP =1.1.1.1 Virtual Server Port=any. My questions is in this scenario the Virtual servers name and configuration on GTM/LTM doesn’t match. How GTM will come to know that Virtual server ABC_VIP_http is available? Bigip monitor will tell the status of Virtual server = ABC_VIP ?LTM will say Virtual server ABC_VIP is available ? How GTM will correlate it to the Virtual Server name=ABC_VIP_http configured on GTM, Thanks
I don’t believe the GTM will be able to match that GTM VIP to the associated LTM VIP since the port is different. Why did you specify the GTM virtual with port 80 instead of “any”?
Shaggy is correct. GTM will not be able to automatically associate a GTM VS with a LTM VS if both the name and IP:port are different. However you can manually assign a LTM VS to a GTM VS if required using tmsh.
modify gtm server  virtual-servers modify {  { ltm-name /Common/ }}
