I see example for delegate myF5 How will it look for company.com?
In your case, replace . is equivalent . “wip” is wide IP subdomain. Some people use F5 or GSLB instead as subdomain to denote that F5 GTM/DNS is revolving names.
company.com
is called the zone apex (where the name is the same as the zone). A zone apex cannot be a
CNAME
- that is a limitation of DNS.
Therefore you cannot use the K277 method, as that describes delegating some other zone to the GTM (called
wip
) and pointing
CNAME
records at it.
If you need
company.com
to be a Wide IP, your GTMs must be authoritative for that zone so that it can answer queries for
company.com
directly.
