Hi All, I just stood up two new DNS devices in AWS, BIG-IP 15.0.1 Build 0.0.11 Final, and I’m running into an error when attempting to run the gtm_add command on the 2nd device. I have TCP 22 and 4353 opened up between the devices but I receive the following error. Does anyone have suggestions? I opened a support case and the sent me a work around to try (K13823) but I’m wondering if there is another way. I’d really like to get the gtm_add command to work instead. Thanks Gang!
[admin@f5-external2:Active:Standalone] ~ # gtm_add admin@xx.xx.xx.xxx
WARNING: Running this script will wipe out the current configuration
files (bigip_gtm.conf, named.conf and named zone files) on the BIG-IP GTM
Controller on which this script is run. The configuration will be
replaced with the configuration of the remote BIG-IP GTM Controller
in the specified sync group
The local BIG-IP GTM MUST already be added in the configuration of the
other GTM.
NOTE: The current master key of this BIG-IP will be changed to match the
master key of the remote BIG-IP GTM.
The BIG-IP config will be saved via:
tmsh save sys config
after the master key is changed.
Are you absolutely sure you want to do this? [y/n] y
Enter admin password if prompted
Password:
Syntax Error: command history is only available in shell mode
ERROR: Can’t read remote cert via /usr/bin/ssh -o UserKnownHostsFile=/home/admin/.ssh/known_hosts .
