GTM 6400 function limit??
I read the GTM datasheet in F5’s portal and i find that it can only addon ipv6 module…
What it means???Can’t 6400GTM addon another module
license like LC or Routing or …??
Why??? Anybody can help me???
You can add the modules you mention to an existing LTM license, and you can add the GTM module to an existing LTM base license, but you cannot add them to the GTM base license.
Since the GTM base product is not intended to perform local or link traffic management, it doesn’t support the same modules LTM does. Support of the IPv6 module is available on GTM, since it is directly relevant to name resolution.
HTH
/deb
