Hi, nice to meet you.
Is it possible to switch to another center if one service port dies after grouping only the service port separately from one IP address among GTM functions?
Currently in one IP
ex)
wide ips: www.test.com
pool: www.1.test.com (1.1.1.1:443, 1.1.1.2: 8122)
pool: www.2.test.com (2.2.2.1:443, 2.2.2.2:8122)
pool: www.3.test.com (3.3.3.1:443. 3.3.3.2:8122)
wide ips: mail.test.com
pool: mail.1.test.com (1.1.1.1:443, 1.1.1.2: 8122)
pool: mail.2.test.com (2.2.2.1:443, 2.2.2.2:8122)
pool: mail.3.test.com (3.3.3.1:443. 3.3.3.2:8122)
wide ips: map.test.com
pool: map.1.test.com (1.1.1.1:443, 1.1.1.2: 8122)
pool: map.2.test.com (2.2.2.1:443, 2.2.2.2:8122)
pool: map.3.test.com (3.3.3.1:443. 3.3.3.2:8122)
The domains www, mail, and ips are each set up in three data center areas. (All 3 GSLBs have config sync completed)
Here, if only one of the pool www.1.test.com dies, can the www and mail pools excluding the map be processed in groups from 1 center to 2 centers?
