I am creating an iApp template and would like to be able to group items in a multichoice select field so that there is a bold header entry that can’t be selected for each group (you can see this behavior for example, when assigning iRules to a virtual server).
I can create the multichoice just fine by separating values by \n, I’m guessing there is some way to define an item as a group header? It looks like returning a tmsh::get_config object would do it for you, but I’m building this list myself.
