set auth_user [HTTP::cookie JetNetUser]
HTTP::header insert JetNetUser $auth_user
It might be wise to avoid the hyphen character in a variable name as it makes referencing it a bit more cumbersome (you need to always enclose it in braces, eg ${auth-user}). I used the underscore character instead in the above example.
