google authenticator with token generator insert into datagroup
Hi All
According to solutions of deploy google authenticator , It provide the idea as below .
I.Design of access policy
II.Google authentication token verification IRULE III.Google authenticator token generator IRULE. = After token generated from the virtual server (IRULE) , the google token key (shared secret key) is need insert to datagroup as below figure.
Regarding No iii , it is the google token key generated from IRULE , administrator need manually insert username + google token key into Datagroup to ensure google authenticator OTP authentication working properly.
As user request more prefer automate solutions, the manual work for insert username + google token key is burden for the administrator . Just wonder is that possible have any workaround or solutions to avoid the manual insert username + token key into IRULE datagroup ?
