Hello There,
We’ve recently switched from Thawte to GoDaddy for our certificates. We run LTM/APM with direct XML broker interrogation as a standard setup, which by and large meets all our needs.
We’ve found that with the GoDaddy WildCard certificate with Receiver on IOS devices won’t launch any applications. All other connections work fine including launching apps out of the portal and using a webtop, Android devices, Receiver on Windows and even Mac. It’s just iDevices that are the issue. We’ve testing with IOS 6 and 7, same thing, applications enumerate but don’t launch sitting at “Starting Application” then bombing out to “Connection Error - Could not connect to server”.
This feels like a firewall issue but of course, this works if we just update the certificate to the Thwate Wildcard (and fiddle with DNS).
The certificate has been bundled with gd_bundle.crt, the bundle cert came through with the certificate during purchase but, I’ve double checked the documentation and the bundled certs, and it’s all correct.
I’m at a loss, don’t really want to purchase a new Thawte Wildcard, not sure if I can get a refund on the GoDaddy.
Hope somebody can help
Frazer
