I am not proficient at writing iControl scripts and could really use some help with this. We are migrating from a 3-DNS 4.5 environment to a GTM 9.3.1 environment, and I am finding that the 3dpipe and iControl commands that we used don’t work anymore. I could really use some examples of what to use, and how to implement it (I really struggle with this stuff!).
Previously, we had a Perl script that used a combination of SSH, 3dpipe and iControl statements to check status of virtual servers configured for wideip’s and then enable/disable a virtual server depending on what datacenter needed to be active for that URL.
The commands that were used were:
3dpipe wideip $wideip pool show
3dpipe wideip $wideip pool $pool virtual show
and,
iControl statements that enable/disable, as follows:
my $soap = SOAP::Lite
→ uri(‘urn:iControl:ITCMGlobalLB/BaseServer’)
→ readable(1)
→ proxy(“https://:443$host/iControl/iControlPortal.cgi”);
$soap_response = $soap->enable_virtual_server(
SOAP::Data->name(
vs => $vs_definition
What are the corresponding 9.3.1 iControl commands that can be used to do these things? Any examples would be greatly appreciate!
Thank you
