I have set up an HTTP receiver as follows:
“metadata”: {
“name”: “syslog-ng”,
“namespace”: “shared”,
“labels”: {},
“annotations”: {},
“disable”: false
“spec”: {
“ns_list”: {
“namespaces”: [
“my-company”
“http_receiver”: {
“uri”: “http://xxx.xxx.xxx.xxx:8084”,
“auth_none”: {},
“compression”: {
“compression_none”: {}
“batch”: {
“timeout_seconds_default”: {},
“max_events_disabled”: {},
“max_bytes_disabled”: {}
“no_tls”: {}
“security_events”: {}
I receive logs but they get repeated on every new POST.
The Test Connection button fails with 504 Gateway Timeout.
On the receiving end, I have a syslog-ng with HTTP receiver, not much configured there.
Any ideas?
