Getting values of json from POST payload not working
Hi Guys,
strange behaviour down here. I’m trying to extract value of parameters from the payload of a POST and send with HSL using the below irule with no success at all: the variables are empty.
Can anyone tell me what’s wrong with it?
set hsl [HSL::open -proto UDP -pool HSL]
set uri [HTTP::uri]
set ip [IP::client_addr]
if {[HTTP::uri] contains “keepal”} {
set data [HTTP::payload]
set namevals [split [HTTP::payload] “&”]
set a 0
set b 0
set c 0
set d 0
for {set i 0} {$i < [llength $namevals]} {incr i} {
set params [split [lindex $namevals $i] “=”]
if { [lindex $params 0] equals “parA” } {
set a [lindex $params 1]
if { [lindex $params 0] equals “parB” } {
set b [lindex $params 1]
if { [lindex $params 0] equals “parC” } {
set C [lindex $params 1]
if { [lindex $params 0] equals “parD” } {
set d [lindex $params 1]
HSL::send $hsl “$ip|$a|$b|$c|$d”
At a minimum you probably want to use the HTTP::collect command and HTTP_REQUEST_DATA event to capture the payload:
    if { ( [HTTP::method] equals "POST" ) and ( [string tolower [HTTP::uri]] contains "keepal" ) } {
        HTTP::collect [HTTP::header Content-Length]
when HTTP_REQUEST_DATA {
    set payload [HTTP::payload]
     All collected payload is available here...
You’re most likely not seeing the payload in the HTTP_REQUEST event because it exceeds a single TCP packet. Using HTTP::collect tells the iRule to collect and buffer the payload (up to the specified amount) and make it available in the HTTP_REQUEST_DATA event. Take a look at the wiki for both of these (command and event) for more thorough implementations.
e.g.
[root@ve10:Active] config  b virtual bar list
virtual bar {
   snat automap
   pool foo
   destination 172.28.19.252:80
   ip protocol 6
   rules myrule
   profiles {
      http {}
      tcp {}
[root@ve10:Active] config  b rule myrule list
rule myrule {
  if {[HTTP::method] eq "POST"}{
    if {[HTTP::header "Content-Length"] ne "" && [HTTP::header "Content-Length"] <= 1048576}{
      set content_length [HTTP::header "Content-Length"]
        set content_length 1048576
    if { $content_length > 0} {
      HTTP::collect $content_length
  set a [URI::query "?&[HTTP::payload]" parA]
  set b [URI::query "?&[HTTP::payload]" parB]
  set c [URI::query "?&[HTTP::payload]" parC]
  set d [URI::query "?&[HTTP::payload]" parD]
  log local0. "a: $a b: $b c: $c d: $d"
 trace
[root@ve10:Active] config  ssldump -Aed -nni 0.0 port 80
New TCP connection 1: 172.28.20.17(50767) <-> 172.28.19.252(80)
1375483782.1026 (0.0012)  C>S
POST / HTTP/1.1
User-Agent: curl/7.15.5 (i686-redhat-linux-gnu) libcurl/7.15.5 OpenSSL/0.9.8b zlib/1.2.3 libidn/0.6.5
Host: 172.28.19.252
Accept: */*
Content-Length: 38
Content-Type: application/x-www-form-urlencoded
parA=one&parB=two&parC=three&parD=four---------------------------------------------------------------
 /var/log/ltm
[root@ve10:Active] config  cat /var/log/ltm
Aug  3 06:49:42 local/tmm info tmm[5139]: Rule myrule : a: one b: two c: three d: four
just a small comment. i think hsl::open should be done in CLIENT_ACCEPTED.
just my 2 cents.
