Hello,
in NodeAdressmain.cs i can’t use those two methods:
-get_object_status
-get_statistics
When i try to use it, i have the exeption :
exeption caught in LocalLB:
iControl:LocalLB/NodeAddress::get_statistics()
Eception : Common : OperationFailed
primary_error_code : 17238054
secondary_error_code : 0
error_string : 01070826:3: current Update Partition Error …
I have the same thing for get_object status.
and the thing is that I just want to display the Node statistics.
methods in localLBAddress.cs:
////////////////////////code//////////////////////
[System.Web.Services.Protocols.SoapRpcMethodAttribute("urn:iControl:LocalLB/NodeAddress",
RequestNamespace="urn:iControl:LocalLB/NodeAddress", ResponseNamespace="urn:iControl:LocalLB/NodeAddress")]
[return: System.Xml.Serialization.SoapElementAttribute("return")]
public LocalLBNodeAddressNodeAddressStatistics get_all_statistics()
{ object[] results = this.Invoke("get_all_statistics", new object[0]);
return ((LocalLBNodeAddressNodeAddressStatistics)(results[0]));
public System.IAsyncResult Beginget_all_statistics(System.AsyncCallback callback, object asyncState)
return this.BeginInvoke("get_all_statistics", new object[0], callback, asyncState);
public LocalLBNodeAddressNodeAddressStatistics Endget_all_statistics(System.IAsyncResult asyncResult)
object[] results = this.EndInvoke(asyncResult);
//In NodeAdressMain:
// Get Statistics
NodeAddress.LocalLBNodeAddressNodeAddressStatistics statistics =
NodeAddress.get_statistics(node_list);
NodeAddress.CommonStatistic[] statistic_list = statistics.statistics[ i ].statistics;
for (int j = 0; j < statistic_list.Length; j++)
Console.WriteLine(
statistic_list[ j ].type.ToString() + " : " + build64(statistic_list[ j ].value)
Plz i need some help and i’m a begginer in c
Hi Mehdis,
I have not seen this error before. If you’re using partitions, check out Joe’s excellent partition overview of partitions here: http://devcentral.f5.com/Default.aspx?tabid=63&articleType=ArticleView&articleId=176
If you are not using partitions, I suspect that the BIG-IP you’re accessing failed in a software update and that’s what’s causing your problem - do you have another BIG-IP you can test against?
Regards,
Don.
the probleem isn’t due to the BIG-IP because the others informations are well displayed.
for example:
SESSION_STATUS_ENABLED
MONITOR_STATUS_UNCHEKED
Connection limit,ratio
I have just this exeption when i want to use “get_statistics” .Yes i’m using partitions(is it an other way tro proceed?)Perhaps it’s just comming from the syntax :
for (int i = 0; i < node_list.Length; i++)
Console.WriteLine(" " +
statistic_list[ j ].type.ToString() + " : " + build64(statistic_list[ j ].value));
PS: Thx for your help and excuse my english. i’m french
Since your code is using the italic command ([ i ])your code is all messed up.
Can you embrace your code with those sign: [ code ] [ / code ] (remove the space)
This way your code should be ok to read!
The italics still show up in “code” blocks so it’s best to use “[ i ]” in code so it won’t transform to a italic html markup.
-Joe
void getNodeInfo(string[] node_list)
// Get Session Status
NodeAddress.LocalLBSessionStatus[] session_status_list =
NodeAddress.get_session_status(node_list);
// Get Enabled State
NodeAddress.CommonEnabledState[] enabled_state_list = NodeAddress.get_session_enabled_state(node_list);
try
Console.WriteLine("Previous Get Object Status");
// Get Object Status
NodeAddress.LocalLBObjectStatus[] object_status_list =
NodeAddress.get_object_status(node_list);
catch (Exception ex)
Console.WriteLine(ex.Message.ToString());
Console.WriteLine(ex.ToString());
Console.WriteLine("After Get Object Status");
Console.Read();
// Get Monitor Status
NodeAddress.LocalLBMonitorStatus[] monitor_status_list =
NodeAddress.get_monitor_status(node_list);
// Get Connection Limit
NodeAddress.CommonULong64[] connection_limit_list =
NodeAddress.get_connection_limit(node_list);
//Get Ratio
long[] ratio_list =
NodeAddress.get_ratio(node_list);
Get Statistics
Console.WriteLine("NODE " + node_list);
Console.WriteLine(" Session Status : " + session_status_list);
Console.WriteLine(" Enabled State : " + enabled_state_list);
Console.WriteLine(" Monitor Status : " + monitor_status_list);
Console.WriteLine(" Availability : " + object_status_list).availability_status);
Console.WriteLine(" Connection Limit : " + build64(connection_limit_list));
Console.WriteLine(" Ratio : " + ratio_list);
Console.WriteLine(" Statistics :");
NodeAddress.CommonStatistic[] statistic_list = statistics.statistics.statistics;
statistic_list[j].type.ToString() + " : " + build64(statistic_list[j].value));
LocalLBNodeAdress :
[System.Web.Services.Protocols.SoapRpcMethodAttribute("urn:iControl:LocalLB/NodeAddress", RequestNamespace="urn:iControl:LocalLB/NodeAddress", ResponseNamespace="urn:iControl:LocalLB/NodeAddress")]
public LocalLBNodeAddressNodeAddressStatistics get_all_statistics() {
public System.IAsyncResult Beginget_all_statistics(System.AsyncCallback callback, object asyncState) {
public LocalLBNodeAddressNodeAddressStatistics Endget_all_statistics(System.IAsyncResult asyncResult) {
public LocalLBObjectStatus[] get_object_status(string[] node_addresses) {
object[] results = this.Invoke("get_object_status", new object[] {node_addresses});
return ((LocalLBObjectStatus[])(results[0]));
public System.IAsyncResult Beginget_object_status(string[] node_addresses, System.AsyncCallback callback, object asyncState) {
return this.BeginInvoke("get_object_status", new object[] {node_addresses}, callback, asyncState);
public LocalLBObjectStatus[] Endget_object_status(System.IAsyncResult asyncResult) {
I tried a simple code and it seems ok (i use 9.4.4):
namespace test_
class Program
static public iControl.Interfaces my_interface;
public static UInt64 build64(iControl.CommonULong64 ul64)
return ((UInt64)(UInt32)ul64.high) << 32 | ((UInt64)(UInt32)ul64.low);
static private void print_stats(string[] node_list)
int i, j;
iControl.LocalLBNodeAddressNodeAddressStatistics Nodes_stats = my_interface.LocalLBNodeAddress.get_statistics(node_list);
for (i = 0; i < node_list.Length; i++)
iControl.LocalLBNodeAddressNodeAddressStatisticEntry Node_stats_entry = Nodes_stats.statistics[ i ];
Console.WriteLine("node: " + Node_stats_entry.node_address );
for (j = 0; j < Node_stats_entry.statistics.Length; j++)
iControl.CommonStatistic Stat = Node_stats_entry.statistics[ j ];
Console.WriteLine("Stats: " + Stat.type.ToString() + ", value -> " + build64(Stat.value).ToString());
static void Main(string[] args)
my_interface = new iControl.Interfaces();
my_interface.initialize("192.168.155.216", "admin", "admin");
if (my_interface.initialized)
print_stats( new string[ ] {"10.1.0.1", "192.168.155.95"} );
else
Console.WriteLine("Connection failed");
