get_statistics trouble
Hey there, im trying to get the stats from one virtual server. I seem to be having trouble though. Am i calling this wrong? My result set is always empty.
Any help would be great,
Cheers,
Adam
(Perl and Big-Ip 9.1.2).
my @vs_list;
my $vs_def = {
name    => $name,
address => $address,
port    => $port
push @vs_list, [$vs_def];
my $soapResponse = $connection->get_statistics(
SOAP::Data->name( virtual_servers => [@vs_list] )
my @res = @{$soapResponse->result->{"statistics"}};
You are giving a bit too much to the get_statistics method…
The signature for VirtualServer::get_statistics is:
VirtualServerStatistics LocalLB::VirtualServer::get_statistics(
    in String [] virtual_servers
In your code you are passing in an array of structures containing the name, address, and port. All you need is an array of strings of the names.
This should get you going:
SOAP::Data->name( virtual_servers => [$name] )
If you want to pass in multiple names, you’ll have to do something like this:
push $vs_list, $name1;
push $vs_list, $name2;
Also, you can check out the LocalLBVSStats.pl sample in the SDK for further reference.
-Joe
