Ok, this is driving me nuts, I am trying to enumerate all the monitors for a particular pool using get_member_monitor_instance. The error I get is below. Calls to get_member_monitor_status, get_member_object_status and get_member_statistics work fine. For the time being, I am using get_monitor_instance but I would prefer to use get_member_monitor_instance.
Would anyone know what I might be doing wrong?
Exception caught in LocalLB:
iControl:LocalLB/Pool::get_member_monitor_instance() Exception: Common::OperationFailed primary_error_code : 16908342 (0x01020036) secondary_error_code : 0 error_string : 01020036:3: The requested monitor rule (1 /Common/mon_docmanager_live_http 3 0 ) was not found.
