Hi, I tried write a script (python) to checking numeber current connection and when is 0 mark member ‘disabled’.
How can I get only value of current connection and then check is 0 ?
member_stat = b.LocalLB.Pool.get_member_statistics( ['/Common/' + pool], [[{'address': member, 'port': port}]])
for statistic in member_stat:
if ( 'STATISTIC_SERVER_SIDE_CURRENT_CONNECTIONS' == 0 ) :
pl.set_member_session_enabled_state(['/Common/' + pool ], [[{'address': member, 'port': port}]], [['STATE_DISABLED']])
pl.set_member_monitor_state(['/Common/' + pool ], [[{'address': member, 'port': port}]], [['STATE_DISABLED']])
no a python expert but here is loop example :
res = b.LocalLB.Pool.get_all_member_statistics(pool_names = ['/Common/pool_turnkey'])
for statistic in res[0].statistics:
print "member ip:port " + statistic.member.address + ":%s" % statistic.member.port
print statistic.statistics[4].type
print statistic.statistics[4].value
if statistic.statistics[4].value.high == 0: print "can be disabled"
output:
member ip:port: /Common/172.16.20.1
(Common.ULong64){
high = 0
low = 0
can be disabled
member ip:port: /Common/172.16.20.3
(Common.ULong64){
high = 0
low = 0
can be disabled
I can’t call attribute like statistics,type,value
AttributeError: 'dict' object has no attribute 'statistics'
