Geolocation with more than one country
I created the below little snippet to check the country code and redirect. What is the easiest way to format the below if I wanted to see if it was from multiple countries like US, JP, CN, etc.
if {[whereis [IP::client_addr]] contains “US”} {
HTTP::redirect “http://www.example1.com/”
HTTP::redirect “http://www.example2.com/”
thanks dean
Using a switch:
    switch -glob [whereis [IP::client_addr]] {
        "*US*" -
        "*CA*" -
        "*UK*" {
            HTTP::redirect "http://www.example1.com/"
        "*MX*" -
        "*CR*" {
            HTTP::redirect "http://www.example2.com/"
        default {
            HTTP::redirect "http://www.example3.com/"
or a datagroup:
ltm data-group internal country-redirect {
    records {
        CA {
            data http://www.example1.com/
        CR {
            data http://www.example2.com/
        MX {
        UK {
        US {
    type string
along with:
    set redir [class match -value -- [whereis [IP::client_addr]] contains country-redirect]
    if { $redir ne "" } {
        HTTP::redirect $redir
    else {
        HTTP::redirect "http://default.example.com/"
