Hi Bamusa, I am trying to achieve something like this only. I have one quarry for you. Can you just tell me for above Irule, how can we add country in “Allowed_list” data group? My requirement is I want to publish one application over internet for India Users only.
I tested this Irule as well. But it is exactly doing opposite of my requirement. Meaning For India Users, It is not opening and sending page with “Blocked!” and for other country users page is opening.. I am working on it but need your help too for doing same.
I confirm this irule allow only from India… Perhaps, the public IP you are using is not assigned to India. Check the localisation database on your F5 with the command: geoip_lookup [your Public IP]
Thanks for your Instant reply… I have already checked location issue. I have two M/C. 1 with DNS address 4.2.2.2 and another with DNS address 121.242.190.211. [root@ltm:Active:Standalone] config geoip_lookup 121.242.190.211 Will attempt to lookup ip ‘121.242.190.211’ No database specified. opening database in /shared/GeoIP/F5GeoIP.dat size of geoip database = 73530756, segments = 16252928, version = GEO-148 20150806 Build 1 Copyright (c) F5 Networks Inc All Rights Reserved geoip_seek = 00f8da67 geoip record ip = 121.242.190.211 country_code = IN country_name = India region_name = Maharashtra continent_code = AS [root@ltm:Active:Standalone] config geoip_lookup 4.2.2.2 Will attempt to lookup ip ‘4.2.2.2’ No database specified. opening database in /shared/GeoIP/F5GeoIP.dat size of geoip database = 73530756, segments = 16252928, version = GEO-148 20150806 Build 1 Copyright (c) F5 Networks Inc All Rights Reserved geoip_seek = 00fb6de1 geoip record ip = 4.2.2.2 country_code = US country_name = United States region_name = Colorado continent_code = NA
