Hi guys, maybe someone can assist me regarding this irule. Our client wants to do Geo Location using this irule.
Any suggestions from your side, its not working, I have tried a couple of different things already.
Thank you, Jacques.
if { [string tolower [HTTP::host]] contains "marksandspencerme.com" && [HTTP::path] eq "/" }{
Parse the client IP from the CDN header
set client_ip [HTTP::header value "Client-IP"]
if { $client_ip eq "" }{
The header was empty/did not exist, so use the actual client IP
set client_ip [IP::client_addr]
set country [string tolower [whereis $client_ip abbrev]]
switch $country {
"JO" -
"EG" -
"BH" -
"KW" -
"QA" -
"OM" -
"LB" {
HTTP::redirect "http://www.marksandspencerme.com/-${country}"
default {
Redirect all others
HTTP::redirect "http://www.marksandspencerme.com/"
pool Pool_www.marksandspencerme.com_2.54_HTTP
