Hi!
We are trying to set up a Geneve tunnel between AWS GWLB and BIG-IP VE AdvWAF, but the BIG-IP is returning reset with cause “RST from BIG-IP internal Linux host”.
Has anyone ever used this before?
Thanks!
Renato A. Ferreira
Hi!
Thanks!
Renato A. Ferreira
Hi Renato,
did you manage to integrate F5 and AWS GWLB?
Br
Andréas
I ran into this issue as well. I was running multi nic with this configuration:
sys db provision.1nic value forced_enable
set this to disabled.
setdb provision.1nic disable
This is a BUG.
Br
Andréas
