Problem this snippet solves:
The following is a little script that should be used as an external monitor. It performs snmpget requests on the node and evaluate the response, based on that returns server status.
Requirements:
- Command line arguments:
- community - the RO snmp community
- oid - the OID to request
- expected_val - the expected value to indicate server is UP
OR
- environment variables:
I found that using the variable is just more clear to configure and view, beside that it’s 100% same
Enjoy,
Lahav Savir lahavs at exelmind dot com
Code :
#!/bin/sh
# application API
dest_ip=$(echo $1 | sed 's/::ffff://'); #IP (nnn.nnn.nnn.nnn notation or hostname)
dest_port=$2;#port (decimal, host byte order)
# you should configure the following variables on the monitor configuration or enable these lines to pass the arguments on the command line
# I just found that it's easier to do it through variables as it's more clear to review them
#community=$3; #community
#oid=$4; #oid
#expected_val=$5; #expected value (for setting monitor UP)
# configurations
pid=$$
timeout=2
up=UP
down=DOWN
loglevel=1
pidfile="/var/run/generic-snmp-monitor-${dest_ip}-${dest_port}-${community}-${oid}.pid"
log_file=/var/log/generic-snmp-monitor-${dest_ip}.log
function write_log ()
echo "$(date +%Y-%m-%d) $(date +%T) ${pid} $*" >> $log_file
function init ()
write_log "=== monitor started ==="
if [ -f $pidfile ]; then
write_log "${pidfile} exist"
kill -9 `cat $pidfile` > /dev/null 2>&1
err=$?
write_log "PID:$(cat $pidfile) killed, error code:${err}"
fi
echo ${pid} > $pidfile
write_log "setting ${pidfile} with pid: ${pid}"
verify_param "dest_ip" "${dest_ip}"
verify_param "dest_port" "${dest_port}"
verify_param "community" "${community}"
verify_param "oid" "${oid}"
verify_param "expected_val" "${expected_val}"
function verify_param ()
name=$1; val=$2;
if [ "${name}" = "" ] || [ "${val}" = "" ]; then
on_error "name:"${name}" or value:"${val}" not set"
fi
#else
# write_log "name:${name} val:${val}"
#fi
function run_snmp_test ()
cmd="snmpget -O qv -t ${timeout} -v2c -c ${community} ${dest_ip}:161 ${oid}"
write_log "cmd=${cmd}"
result=$(${cmd})
err=$?
if [ ${err} -ne 0 ]; then
on_error "snmpget existed with error code:${err}"
fi
if [ "${result}" = "${expected_val}" ]; then
write_log "OK - RESULT:${result} as expected"
response ${up}
else
write_log "FAIL - RESULT:${result} != ${expected_val}"
response ${down}
fi
function response ()
status=$1
write_log "response status:${status}"
if [ "${status}" = "${up}" ]; then
echo ${status}
fi
function cleanup ()
write_log "deleting ${pidfile}"
rm -f ${pidfile} >/dev/null
function on_error ()
write_log "ERROR: $1"
response ${down};
cleanup;
write_log "=== monitor aborted ==="
exit -1
function main ()
init;
run_snmp_test;
cleanup;
write_log "=== monitor ended ==="
exit 0
main;
Why is this monitor failing when the ‘echo’ is done in function response ()?
i have re-downloaded this and it still fails to complete the script. i have put it on another system and it also fails to complete the script.
If I log right after the echo it doesn’t appear in the log.
It have tried moving the echo response and it doesn’t matter. It seems that as soon as the echo is issued the process finishes and nothing else is processed including the remove of the pid file. The next time it runs it finds the file and errors trying to kill the process (that had finished!).
Well as soon as anything is written out (Echo command) the script stops. so the cleanup will not occur on this script.
This is really crazy.. and spent most of the day to figure out what had been mentioned by hoolio a few times (found a template he posted and a comment that revealed it).
The following provides the equivalent to the original submission in this post. While the structure of that code is very nice, and it will work, the script stops before cleanup is completed leaving a dangling pid file that could kill non-related process.
Using the template and adding the SNMP portion of the code from above results in:
!/bin/bash
Save as /usr/bin/monitors/custom_monitor.bash
Make executable using chmod 700 custom_monitor.bash
Use a custom shell command to perform a health check of the pool member IP address and port
Log debug to local0.debug (/var/log/ltm)?
Check if a variable named DEBUG exists from the monitor definition
This can be set using a monitor variable DEBUG=0 or 1
if [ -n "$DEBUG" ]
then
if [ $DEBUG -eq 1 ]; then echo "EAV `basename $0`: \$DEBUG: $DEBUG" | logger -p local0.debug; fi
else
If the monitor config didn't specify debug, enable/disable it here
DEBUG=0
fi
Remove IPv6/IPv4 compatibility prefix (LTM passes addresses in IPv6 format)
IP=`echo $1 | sed 's/::ffff://'`
Save the port for use in the shell command
PORT=$2;
commented below as they are now sent as variables from the monitor rather than arguments
community=$3; community
oid=$4; oid
expected_val=$5; expected value (for setting monitor UP)
Check if there is a prior instance of the monitor running
pidfile="/var/run/`basename $0`.$IP.$PORT.pid"
if [ -f $pidfile ]
then
echo "EAV `basename $0`: exceeded monitor interval, needed to kill ${IP}:${PORT} with PID `cat $pidfile`" | logger -p local0.error
fi
Add the current PID to the pidfile
echo "$$" > $pidfile
Debug
if [ $DEBUG -eq 1 ]
then
Customize the log statement here if you want to log the command run or the output
echo "EAV `basename $0`: Running for ${IP}:${PORT} using custom command" | logger -p local0.debug
fi
Customize the shell command to run here.
Use $IP and $PORT to specify which host/port to perform the check against
Modify this portion of the line:
nc $IP $PORT | grep "my receive string"
And leave this portion as is:
'2>&1 > /dev/null'
The above code redirects stderr and stdout to nothing to ensure we don't errantly mark the pool member up
Send the request request and check the response
snmpget -On -c $community $IP $oid | grep "$expected_val" 2>&1 > /dev/null
Check if the command ran successfully
Note that any standard output will result in the script execution being stopped
So do any cleanup before echoing to STDOUT
if [ $? -eq 0 ]
then
rm -f $pidfile
if [ $DEBUG -eq 1 ]; then echo "EAV `basename $0`: Succeeded for ${IP}:${PORT}" | logger -p local0.debug; fi
echo "UP"
else
rm -f $pidfile
if [ $DEBUG -eq 1 ]; then echo "EAV `basename $0`: Failed for ${IP}:${PORT}" | logger -p local0.debug; fi
fi
