Generate a unique ID with the help of an iRule
Hello everyone
I would like to generate a unique ID with the help of an iRule and place it in a header. The goal is to identify the HTTP request by the ID. Has anyone done something like this before?
What I have tried:
when HTTP_REQUEST priority 3 {
###Generate URL Tracing
for { set i 0 } {$i < 8 } { incr i } {
append rand_hex [format {%x} [expr {int(rand()*16)}]]
#log local0. "X-Request-ID: $rand_hex"
###Add X-Request-ID Header
if {not([HTTP::header exists X-Request-ID ])}{
	HTTP::header insert X-Request-ID $rand_hex
when HTTP_RESPONSE priority 3 {
The problem is that I sometimes see multiple requests with the same ID. Does anyone have a better idea how to solve it?
Dan44,
I’m not sure about generating the unique ID, I’d look at this article Random String Generators - Community CodeShare - DevCentral - An F5 Technical Community or keep it simple and generate an id like Kai Wilke suggested in https://devcentral.f5.com/s/question/0D51T00006i7W29/how-random-is-rand
set uniqueID [TMM::cmp_unit][clock clicks]
Your code also allows a client to supply the header X-Request-ID, is this intended behaviour?
Rob
Hi Rob
Thanks for your reply, the links look interesting. I will have a look at them and test the examples.
Regarding your question. It is actually planned that only F5 LTM does the header insert and not the client.
if that is the case you should remove the HTTP_RESPONSE part
