Gateway Failsafe in V10 missing
recently upgraded to ver 10 and the gateway failsafe is no longer available as an option under the web GUI!!!
Please advice
If there is any for v10 I would suspect you would find that on ask.f5.com
Here is an link to one:Click here
I hope this helps
Bhattman
your link doesnt work!. Can someone pls confirm if this feature is supported in v10.
thanks
Posted By Bhattman on 01/29/2010 9:01 AM
I hope this helps
Bhattman
The link was updated. It should work now.
I don’t have a v10.0 box, but the option is certainly there for 10.1.0 (Under High Availability:Fail-safe:Gateway)
H
It’s in the same location in 10.0.1.
Aaron
