Problem this snippet solves:
iRule CRYPTO commands do not allow the use of SSL / TLS certificates for encryption and decription operations.
This snippet provides a simple way to extract the RSA Public key from a x509 certificate by parsing its ASN.1 structure. The output key can then be given as [-key] input to the CRYPTO::[encrypt|decrypt] commands in combination with the use of the rsa-pub and rsa-priv algorithms [-alg].
The example only encrypts a test string with the Client’s SSL certificate to demonstrate the functionality but you have unlimited options here.
For instance, you are not limited to using your client’s certificate (e.g. [SSL::cert 0]): any PEM (base64) or DER representation of a public x509 cert will also work. When using the PEM format just don’t forget to perform a b64decode before feeding it to the getRSAPubFromX509 proc.
Credits to Kevin Stewart for the original idea and code for performing Extended X509 Certificate Parsing
How to use this snippet:
- Create Virtual Server
- Select “http” under “HTTP Profile”
- Create SSL Profile (Client)
3.1 Configure the “Certificate Key Chain” with a proper or self-signed ssl key pair
3.2 Select “require” under “Client Certificate” - Assign the SSL Profile to the Virtual Server
- Create an iRule out of the snippet below and assign it to the Virtual Server
- Generate traffic by use of an appropriate client SSL key pair
- JSON Parse the response.
Test decryption with openssl:
Copy the “encryptedMsg” JSON value within the response payload (e.g. using JSON.Parse()) in a file called enc.txt, then decode it from base64 into the encrypted binary string and use the client’s private key to decrypt.
base64 -d enc.txt > encbin.txt
openssl rsautl -inkey key.pem -decrypt -in encbin.txt
Code :
set cert [SSL::cert 0]
set rsaFromX509 [call getRSAPubFromX509 $cert]
log local0. "PEM encoded RSA Public: $rsaFromX509"
set testString "test string to encrypt"
set encBytes [CRYPTO::encrypt -alg rsa-pub -key $rsaFromX509 $testString]
set encBytesPrintable [b64encode $encBytes]
log local0. "Encrypted b64encoded string: $encBytesPrintable"
set jsonResponse "{ \"encryptedMsg\": \"$encBytesPrintable\" }"
HTTP::respond 200 content $jsonResponse
proc getRSAPubFromX509 { bincert } {
if { [catch {
# rsaEncryption OID=1.2.840.113549.1.1.1 - HEX=\x06\x09\x2A\x86\x48\x86\xF7\x0D\x01\x01\x01
set offset [string first \x06\x09\x2A\x86\x48\x86\xF7\x0D\x01\x01\x01 $bincert]
# Shift the offset before the ASN.1 sequence length
set offset [expr { $offset - 4 }]
binary scan "[string index $bincert $offset][string index $bincert [expr $offset + 1]]" S seqlen
# Convert the ASN.1 length to unsigned integer
set seqlen [expr {$seqlen & 0xffff}]
# Set a pointer to the beginning of the sequence
set startSeq [expr $offset - 2]
# Set a pointer to the end of the sequence
set endSeq [expr $startSeq + 3 + $seqlen]
set rsaEncryption [string range $bincert $startSeq $endSeq]
} error] } {
set rsaEncryption 0
if { $rsaEncryption == 0 } {
return 0
binary scan $rsaEncryption a* rsaEncryption
set encodedKey [b64encode $rsaEncryption]
set formattedKey "-----BEGIN PUBLIC KEY-----\x0A"
for {set i 0} {$i < [string length $encodedKey]} {incr i 64} {
set formattedKey "${formattedKey}\x0A[string range $encodedKey $i [expr {$i + 63}]]"
set formattedKey "${formattedKey}\x0A-----END PUBLIC KEY-----\x0A"
return $formattedKey
Tested this on version:
12.1
