Problem this snippet solves:
Summary: An FTP proxy that simulates FTP proxies found on Bluecoat and Cisco Ironport Proxies.
Contribution
Bhattman at gmail dot com
How to use this snippet:
NOTE: You need to apply the FTP Profile
Code :
when CLIENT_DATA {
set ftplogin [TCP::payload]
log local0. "login is $ftplogin"
if { $ftplogin starts_with "USER" } {
# You can set it up to use any DNS server you want.
set dnslookup "4.2.2.1"
set cuser [TCP::payload]
scan $cuser {%[^@]@%s} garbage sitename
scan $garbage %s%s cmd uid
set ips [RESOLV::lookup @$dnslookup -a $sitename]
if {$ips eq "" } {
# Input wasn't an IP address, take some default action?
reject
TCP::payload replace 0 [TCP::payload length] ""
set ftp_serv "[lindex $ips 0]"
node [lindex $ips 0] [TCP::local_port]
TCP::release
when SERVER_CONNECTED {
TCP::collect 20
when SERVER_DATA {
set serv_data [TCP::payload]
if { $serv_data contains "220" } {
TCP::respond "USER $uid\r\n"
TCP::release
Tested this on version:
10.0
