we are deploying new Virtual Servers in 11.6.0 using the FQDN node feature.. we have observed that when the DNS record for the FQDN is changed that the old record remains as an ephemeral node and is kind of “stuck” in the virtual server.
This is a problem for us as the that previous web server system might still be live, and I am wondering if this can be flushed when a new record is learned after the timeout period. ?
We often switch URL’s to the DR platform, and then switch back using DNS.. we don’t want the DR system to be present after the switchback.
can you try to restart bigd? i may be wrong but i think bigip will resolve fqdn node when bigd is restarted.
restart bigd
[root@ve11c:Active:In Sync] config tmsh list ltm node google
ltm node google {
fqdn {
autopopulate enabled
name www.google.com
state fqdn-up
[root@ve11c:Active:In Sync] config date; tmsh restart sys service bigd
Tue May 12 19:25:42 SGT 2015
tcpdump
[root@ve11c:Active:In Sync] config tcpdump -nni 0.0 -s0 port 53
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on 0.0, link-type EN10MB (Ethernet), capture size 65535 bytes
19:26:01.144898 IP 172.28.24.13.33478 > 8.8.8.8.53: 26437+ A? www.google.com. (32) out slot1/tmm1 lis=
19:26:01.150778 IP 8.8.8.8.53 > 172.28.24.13.33478: 26437 6/0/0 A 74.125.130.105, A 74.125.130.103, A 74.125.130.147, A 74.125.130.99, A 74.125.130.106, A 74.125.130.104 (128) in slot1/tmm1 lis=
19:26:06.149613 IP 172.28.24.13.48936 > 8.8.8.8.53: 26437+ A? www.google.com. (32) out slot1/tmm1 lis=
19:26:06.157343 IP 8.8.8.8.53 > 172.28.24.13.48936: 26437 5/0/0 A 173.194.117.115, A 173.194.117.114, A 173.194.117.113, A 173.194.117.116, A 173.194.117.112 (112) in slot1/tmm1 lis=
restart bigd
ltm node google {
fqdn {
name www.google.com
state fqdn-up
tcpdump
