Torti
January 9, 2018, 7:19pm
1
Im playing a little bit with fqdn nodes after upgrade to 12.1.3
If I add a fqdn node and add a dns entry a ephemeral node will be added with the ip. so far so good.
If I change the DNS entry to another ip entry, the ephemeral node is replaced by a new one with the new ip. Nice again.
The problem:
If I remove the DNS entry, the ephemeral node still exist.
Do I need to create a individual monitor with the DNS entry to mark the node as down, althoug the f5 itself checks the fqdn node in interval?
symptom:
a pool member is still online, if a system is replaced by another system with the same base configuration.
Is there a easy solution for that?
Thx
You don’t need a DNS monitor. F5 makes a DNS resolution based on the configuration you setup for that. It should remove, or replace, the node/member if not getting that from the DNS query. The only situation that may cause delay here to remove is if there is a connection open to that member, as I am not sure if deletes and close the connection, or waits to finish or time out.
Have a look in this solution:
nitass
January 11, 2018, 1:36pm
3
have you tried to enable monitor logging? is there anything useful in log file (/var/log/monitors/)?
tmsh modify ltm node logging enabled
Torti
January 11, 2018, 3:51pm
5
by default, we are not monitoring nodes, only pool member.
I will try it with an icmp
Torti
6
nitass
January 14, 2018, 4:26am
7
i might misremember. i thought i did see /var/log/monitors without health monitor assigned.
anyway, i did a bit test your scenario here and it seemed okay. i am on 13.1.0.1.
// has record
[root@ve13a:Active:In Sync] config tcpdump -nni 0.0 -s0 port 53
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on 0.0, link-type EN10MB (Ethernet), capture size 65535 bytes
13:06:35.935529 IP 200.200.200.11.52454 > 200.200.200.16.53: 55672+ A? www.acme.local. (32) out slot1/tmm1 lis=
13:06:35.936526 IP 200.200.200.16.53 > 200.200.200.11.52454: 55672*- 1/1/1 A 200.200.200.200 (81) in slot1/tmm1 lis=
[root@ve13a:Active:In Sync] config tmsh list ltm node
ltm node _auto_200.200.200.200 {
address 200.200.200.200
ephemeral true
fqdn {
interval 60
name www.acme.local
ltm node testnode1 {
fqdn {
interval 60
name www.acme.local
state fqdn-up
[root@ve13a:Active:In Sync] config tmsh list ltm pool
ltm pool testpool1 {
members {
_auto_200.200.200.200:80 {
ephemeral true
fqdn {
name www.acme.local
testnode1:80 {
fqdn {
name www.acme.local
state fqdn-up
// no record
13:08:35.940014 IP 200.200.200.11.52454 > 200.200.200.16.53: 22762+ A? www.acme.local. (32) out slot1/tmm1 lis=
13:08:35.940793 IP 200.200.200.16.53 > 200.200.200.11.52454: 22762 NXDomain*- 0/1/0 (83) in slot1/tmm1 lis=
fqdn {
interval 60
name www.acme.local
state fqdn-up-no-addr
members {
testnode1:80 {
fqdn {
name www.acme.local
