FQDN ephemeral node logging
is there any log or a way to log, when an ephemeral node is changed? Especially when the entry is deleted because of a missing DNS entry. Or the creation a new one.
Thx
Hi Torti,
Do you know the TTL for the node FQDN? Running
tmsh list /ltm node * all-properties
should provide this information.
You’re not going to know if a change has been made (e.g. node address is changed or deleted) unless you track the TTL of the node somehow.
You could write an iRule to capture this information but that would be event driven. I assume you want this information independent of the node being configured as a pool member, correct?
Hi Torti,
your command shows the ttl configuration, only.
you do not see the actually lifetime of the object.
The creation of a ephermeral node is visible in the gui. If you select the object, you can see the DNS availability with a timestamp. But if a ephermeral object is removed, you don’t get any information about that. You only get an log message, if the FQDN object doesn’t have a ephermeral node anymore.
In my opinion, this is a bad design.
