Forwarding VS - with selective irule for SRC to DST only allowed to access (using data groups) - syntax fail
Hello this syntax looks logical to me, but is rejected. Can someone please help to tell me what i am doing wrong?
when CLIENT_ACCEPTED {
if {([class match [IP::client_addr] equals L2L_SITEA_SUBNETS] && [class match [IP::local_addr] equals L2L_SITEB_SUBNETS])}
forward
return
elseif {([class match [IP::client_addr] equals L2L_SITEB_SUBNETS] && [class match [IP::local_addr] equals L2L_SITEA_SUBNETS])}
forward
return
else
drop
it seems okay here. you have created data groups, haven’t you?
root@(ve11c)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm rule qux
ltm rule qux {
  if { ([class match [IP::client_addr] equals L2L_SITEA_SUBNETS] && [class match [IP::local_addr] equals L2L_SITEB_SUBNETS]) } {
    forward
    return
  } elseif { ([class match [IP::client_addr] equals L2L_SITEB_SUBNETS] && [class match [IP::local_addr] equals L2L_SITEA_SUBNETS]) } {
    forward
    return
    drop
Yes Data Groups have been defined (each contains multiple subnets). Removed the word “return” for the if and the elseif statement - which fixed issue
