Tpic says it all. Is there some example code for that anywhere?
This code will create an IP Forwarding Virtual. You’ll need to modify the code to change the virtual address, name, default_pool, and profiles.
!/usr/bin/perl
The contents of this file are subject to the iControl Public License
Version 4.5 (the "License"); you may not use this file except in
compliance with the License. You may obtain a copy of the License at
http://www.f5.com/.
Software distributed under the License is distributed on an "AS IS"
basis, WITHOUT WARRANTY OF ANY KIND, either express or implied. See
the License for the specific language governing rights and limitations
under the License.
The Original Code is iControl Code and related documentation
distributed by F5.
The Initial Developer of the Original Code is F5 Networks,
Inc. Seattle, WA, USA. Portions created by F5 are Copyright (C) 1996-2003 F5 Networks,
Inc. All Rights Reserved. iControl (TM) is a registered trademark of F5 Networks, Inc.
Alternatively, the contents of this file may be used under the terms
of the GNU General Public License (the "GPL"), in which case the
provisions of GPL are applicable instead of those above. If you wish
to allow use of your version of this file only under the terms of the
GPL and not to allow others to use your version of this file under the
License, indicate your decision by deleting the provisions above and
replace them with the notice and other provisions required by the GPL.
If you do not delete the provisions above, a recipient may use your
version of this file under either the License or the GPL.
use SOAP::Lite;
Validate Arguments
my $sHost = $ARGV[0];
my $sPort = $ARGV[1];
my $sUID = $ARGV[2];
my $sPWD = $ARGV[3];
my $sProtocol = "https";
if ( ("80" eq $sPort) or ("8080" eq $sPort) )
$sProtocol = "http";
sub usage()
die ("Usage: PoolMember.pl host port uid pwd ([pool] AND [enable|disable])\n");
if ( ($sHost eq "") or ($sPort eq "") or ($sUID eq "") or ($sPWD eq "") )
usage();
Transport Information
sub SOAP::Transport::HTTP::Client::get_basic_credentials
return "$sUID" => "$sPWD";
$VirtualServer = SOAP::Lite
-> uri('urn:iControl:LocalLB/VirtualServer')
-> readable(1)
-> proxy("$sProtocol://$sHost:$sPort/iControl/iControlPortal.cgi");
Attempt to add auth headers to avoid dual-round trip
eval { $VirtualServer->transport->http_request->header
'Authorization' =>
'Basic ' . MIME::Base64::encode("$sUID:$sPWD", '')
support for custom enum types
sub SOAP::Deserializer::typecast
my ($self, $value, $name, $attrs, $children, $type) = @_;
my $retval = undef;
if ( "{urn:iControl}Common.EnabledState" == $type )
$retval = $value;
return $retval;
Main logic
&createForwardingVirtual();
sub createForwardingVirtual()
$VirtualServerDefinition =
name => "my_forwarding_virtual",
address => "90.90.90.90",
port => "80",
protocol => "PROTOCOL_TYPE_TCP"
$wildmask = "255.255.255.255";
$VirtualServerResource =
type => "RESOURCE_TYPE_IP_FORWARDING",
default_pool_name => ""
$VirtualServerProfile =
profile_context => "PROFILE_CONTEXT_TYPE_ALL",
profile_name => ""
$soapResponse = $VirtualServer->create
SOAP::Data->name(definitions => [$VirtualServerDefinition]),
SOAP::Data->name(wildmasks => [$wildmask]),
SOAP::Data->name(resources => [$VirtualServerResource]),
SOAP::Data->name(profiles => [[$VirtualServerProfile]])
&checkResponse($soapResponse);
print "Virtual Server Created!\n"
checkResponse makes sure the error isn't a SOAP error
sub checkResponse()
my ($soapResponse) = (@_);
if ( $soapResponse->fault )
print $soapResponse->faultcode, " ", $soapResponse->faultstring, "\n";
exit();
-Joe
Sorry to hear the code samples are hard to find, I’ll have to try to do something about that. At least you like them when you find them B-).
In the future, I’ve got all my iControl samples in the iControl categorized under dev language. When I post an example in a tech tip or forum post, I’ll also put it over in the wiki. Here’s some good reference pointers.
Thanks for posting your code as well! Also, hope you don’t mind I put some code brackets around your post and shortened up some of the lines so that the browser didn’t scroll into infinity B-)
-Joe
