What is the difference between Forwarding VIP - 0.0.0.0 and the default route. Both serves same purpose?. Can we just use anyone?.
Default route & Forwarding VIP are different.
Forwarding VIP: IP forwarding VIP accepts traffic that matches the VIP and forwards it to the destination IP address that is specified in the request rather than LB the traffic to a pool. NAT/SNAT is disabled when you create an IP forwarding VIP, leaving the destination address in the packet unchanged. Go through article
Default Route: It is a set of standard routes for each route domain on the BIG-IP system. This route uses for the LB pool subnet if gateway didn’t match with existing route(which is defined) for POOL VLAN provision subnet.
