If you are configuring the listner to forward queries to a DNS server,you should give the listener the IP address as that DNS server,and the listener's associated DNS profile show have the **Use BIND Server on BIG-IP** option set to **disabled**
is this correct?
Correct.
- The listener IP address should be the IP address of the local DNS server.
- The DNS profile associated with the listener must have ‘Use BIND Server on BIG-IP’ disabled.
