Forward to VS based on URI? - firepass to APM migration
Hi, we are currently migrating from Firepass to APM, currently we have a load of URI’s that people connect to on the firepass and get various policies applied and customisation depending on which one they connect to.
I was wondering if it is possible to use an iRule in APM to forward requests to a VS with a sepecific access policy assosiated with it. I know you can have a uri check in the VPE but I think that the policy could start to get very large if we have say 20 braches coming off the URI check with a separate logon page and resource assign on each (although I guess we could have each branch going to a macro and leep it tidy that way). I think it would be neater to have one access policy per uri.
Does anyone out there do something in a similar way?
Many thanks
Yes, we do that often.
Use the HTTP_REQUEST event on the front virtual server.
  switch -glob [HTTP::uri] {
      "abc*" { virtual abc }
      "def*  { virtual def }
      default { HTTP::respond 200 content "You are in the wrong place." }
HTH
OK thanks, so if I can get this to work, it should save me from using up lots of public IP’s, I can have 1 x external IP and people will get the policy they need based in the uri they enter?
I will give it a go Thanks
What version are you running? If you are using 11.4.x code, I would wonder if Local Traffic policy might be an option for you?
Hi, we are running 11.4.1, I will have a look at local traffic policy if that will achieve the same goal. We will only be buying a license for APM though so not sure how many LTM options we will have? May need to speak to my reseller.
John, I have got this to work, however it appears that when I connect to the virtual server with the APM access policy associated it changes to uri to be /my.policy and I get the ‘you are in the wrong place message’ Any ideas?
So I have a device that is only ASM licensed and there are still a lot of options to utilize in Local Traffic policy even without LTM licensing. It looks to me a lot of HTTP functionality that you had to do in a iRule in previous version can now be accomplished in LT policy with rules
