Hi
We want to create new Virtual server wildcard Outbound with standard type and port 443.
The thing is we want to decrypt to inspect and modify some http header of some host too.
example. If we access ";, F5 should perform irule and send it to pool A but if other user access ";, F5 should do nothing and send traffic normally.
What need to do between Forward SSL proxy and Proxy SSL?
Is both an additional license? Thank you
