forward Client Ip Address over port 104 Dicom
virtual server needs to forward the client ip address to the server.
Client ip --> f5 VS port 104 --> Server ip port 104
You can utilize the “X-Forwarded-For” header. It adds a header containing the clients original IP address.
HERE is some info on that!
Hope that helps! If it does please up-vote and select this answer, it’d be greatly appreciated!
-Dylan
Hi Dylan,
thank you for your reply. we did try the solution you have mentioned.
As this traffic is initiated from a ultrasound machine --> f5 --> Servers over port 104.
is there another way we can forward the client ip to the servers from the f5.
-Adnan
