Anybody know how to force pool members offline from the configuration utility?
According to support KB 404 Page not found | BIG-IP Documentation I should be able to click the “Force Offline” button. But there is now “Force Offline” button. I believe I remember seeing the button in previous builds, but I can’t find it anywhere now.
nathan, looks like that is the way to do it. However this sure is a real pain. If I have like 20 pool members on 5 servers, having to click into each pool member and force offline sure takes a long time.
I just checked on 11.6.0 HF-3 and the force offline button is available on the pool member screen. You can open a case to find out if it has been removed on 11.5.1 HF-7 for a reason or if it is a bug.
