Hey Everyone:
I recently completed setting up an edge pool for my Skype for Business 2015 deployment and all of my services are working as intended (IM/Presence and Video calls). I now wish to deploy reverse proxy services to allow mobile devices to connect externally. Fortunately for me I just so happen to have a BIG-IP in my DMZ and another BIG-IP in my internal network with my FE pool.
I am a bit confused about the ports that need to be open on different sides of the networks. I understand that the DMZ F5 is going to get it’s own public IP address which will be NAT’d to my DMZ subnet where my DMZ F5 “lives”. I understand also that I will specifically be NAT’ing TCP 80 and 443 to the BIG-IP.
Using the iApp I am going to have it forward reverse proxy traffic over to my internal BIG-IP which “lives” on my messaging subnet (just the subnet I have Skype and Exchange running on) and the internal will have the Skype iApp configured to receive the reverse proxy traffic from the DMZ Bip IP.
My question is, do I open ports 443 and 80 between the two BIG-IP’s and then have 4443 and 8080 open between the internal Bip Ip and the FE pool? Or is there something I am missing where I’d open 4443 and 8080 between the two BIG-IP’s (which I don’t think is the case, just verifying).
Thanks all!
So when you have a split deployment as mentioned for reverse proxy traffic then BIG-IP 1(DMZ) would receive traffic and forward to BIG-IP 2 (internal, in front of FE servers) on the already translated port 4443. BIG-IP 2 will then pass that through to individual FE servers on the same 4443 port.
So the real answer to your question is between the two BIG-IP’s you should allow for 80, 8080, 443 and 4443 to ensure traffic processing.
Although just to suplement that answer the traffic is going to be 443 when it hits dmz and then 4443 between BIG-IP’s. However opening up the other ports may be required depending on the other S4B services you are deploying.
Followup question. I understand that i need to allow the traffic such as this:
WAN/NAT → DMZ Reverse proxy VIP DMZ BIG-IP Self IP → Internal Reverse Proxy VIP
But what about the return path? Do I allow the traffic back from the Internal BIG-IP VIP to the DMZ BIG-IP self IP? Or does it turn around and try to send from Internal BIG-IP Self IP → DMZ Self IP?
Or am I completely missing the target here?
Thanks again!
The return path will be the same (dmz self ip to internal vip). Snat auto map is applied on the DMZ vip for reverse proxy traffic, so internal reverse proxy vip sees traffic as sourced from dmz BIG-IP self ip (as you stated).
So just to be clear, because for some reason I am having a brain glitch when reading that reply (my apologies for being dense!), on the path BACK OUT to DMZ going from internal to external, the VIP is the IP sending back to the DMZ self ip rather than it passing the return process off to the internal self IP, correct?
This makes sense from a networking perspective, I just wanna make sure I’m 100% clear. Thanks again and sorry for being repetitive!
That is correct, clarifying is never being dense, just thorough!
