I was able to find a reletively recent version of a document that shows operating system and browser versions supported by firepass FirePass - but the only thing that shows what versions of antivirus is a couple years old. Is there a “living” document of what’s currently supported by FirePass using opswat?
TIA,
Eric
I haven’t seen a living document but if you install the latest version of Opswat and go to the Firepass built-in knowledge, it will show the updated list.
Eric,
If you click on “Help” in the upper right and corner and then go to “Users” > “Endpoint Security” > “Inspectors” > “Antivirus Support Chart”. You will then see the Windows, Mac and Linux Support Charts for what version of OPSWAT you have installed.
Seth
Posted By Seth Cooper on 09/07/2012 08:37 AM
Eric,
Seth
Thanks Seth!
