Does anyone else have a problem with Firepass logging? Personally I think it’s awful. Too difficult to find anything you need. Things you want to report on aren’t possible. Especially if users connect to the Network Access Client. Once the connection is made, you can’t tell what happened after that until they log off, then all you have are the connection times. I opened a case with F5 and put in a request for improvement and got turned down stating it would be too difficult to code and too CPU intensive on the box which I don’t buy. If you think the logging sucks please bang on F5’s support about it. Thanks!
Have you seen the stuff that Splunk is doing for FirePass logging?
Can you describe what kind of logging you’re looking for and not finding?
There may be other ways to find similar information depending on your environment. For example if you’re using a routed subnet for Network Access clients and have access to your router, perhaps using netflow might meet your needs.
Just dump the logs to syslog..
Firepass logs on the units are a bear to look thru..
You can adjust how much and what info gets dumped to syslog..
It should meet all your needs.
VictorS
Enter the settings here to connect to a syslog server and also edit the info above with how much you would like to gather
Enable Remote Log Server
Enable Extended System Logs
Remote host
Log level
Kernel log level
