We have a Firepass unit running 6.1.0. Is it possible to set the inactivity timeout to NEVER expire for a particular user (linux client?) or at least extend the inviduals setting for a longer timeout period than the default?
Thank you,
Thank you,
Yes and No ![]()
Yes, you can set the inactivity timeout for a certain user group or create a separate user group for that user. No, you can’t set it for an individual if you don’t do the above.
