Fiorano HA and LTM
Does anyone have any experience using the LTM module in conjunction with a Fiorano Messaging Queue (MQ2007) in an HA setup?
Regards,
Jacob
I haven’t personally seen anything like that come across the forums that I can recall. Is there a specific issue you’re having or trying to work through?
If you have some questions or details about a problem, the community might be able to answer them without specific knowledge of that particular setup.
Colin
