I use a vip that has serverssl enabled. On one specific pool I should use “SSL::enable serverside” and on the others “SSL::disable serverside”.
This works fairly well, but how do I find out which mode I’m actually using? The SSL::mode seems only displaying the clientside, ie I’m always getting true for SSL::mode whatever mode I’m actually using on the serverside.
I could always set my own variable, but I would like to know how the irule has decided.
Mainly I need it for debugging right now. But if there is a check for SSL-mode it would be nice to know what the TMM has selected.
I use a line like this in the end of the rule:
if {$debug == 1 } {log local0. "URI=[HTTP::uri], using server [LB::server], SSL=[SSL::mode]"}
So I can see what server and port (serverside), but not the protocol. I can see however SSL-traffic whith tcpdump where there shouldn’t be. So I have some kind of bug in my irule. Need to find it.
What event are you using SSL::mode in? Can you post your full rule or the relevant portions?
Aaron
I’m using HTTP_REQUEST and HTTP_REQUEST_DATA, since I need to check POST-requests.
It would be a good thing if I could use a generic log-line at the end of the rule that checked what pool-member was selected and protocol and so on. I can check for pool-member with LB::server but not if I’m using SSL or HTTP as protocol.
And the sometimes I get the wrong protocol to the server, so to find out what ssl-mode on the serverside and not only the client-side would be nice.
I’m not attaching any rule, since this is an generic question of the possibilitys reading variables and states.
You can check for a serverssl profile with the PROFILE::exists command. The serverssl profile isn’t attached to the VIP until the server side context, sothe first event you can get a valid result in is HTTP_REQUEST_SEND.
I have a faint recollection of one of the developers saying that the PROFILE:: command is expensive in terms of CPU. So if you don’t need to use it in production, it might be better not to. Maybe someone can provide more correction/clarification on this.
if {([PROFILE::exists serverssl] == 1) && ([PROFILE::serverssl mode] == 1)} {
log local0. "Server SSL enabled"
log local0. "Server SSL not enabled"
when HTTP_REQUEST_SEND {
